I guess a lot of you will answer this after the weekend but a lot of talk has been said re how far we can go on a tank so:
how big is your fuel tank and how far can you get on it.
Also how big a tanK can a 7 get in ?
....... Neil
How big is your fuel tank
Re: How big is your fuel tank
How High is a Chinaman?
sorry had to do that
Well as the rear ends are all a bit different really depends on the car Neil.....Caterhams have an 8 gall tank that seems to be quite flat giving a worthwile boot area. Standard on a Tiger is 6.5 gallons but on the S/Cat its possible to increase the height - which i did, so have a tad over 8 gallons. If i'd had the time and inclination to measure the gap more precisely i reckon that getting 9.5 gallons would have been easily achievable. When i was running carbs i seemed to have to fill up before putting it back in the garage or very quickly after taking it out to play. With the TB's and bigger tank 200+ miles at cruising speed.
- Ianz18Avon
Neil,
Mine does/did about 100 miles to a tankfull, standard tiger petrol tank.
Mark,
Chester Sports Cars used to do a "touring" petrol tank but I have no idea have big that was.
Ian
Mark,
Ian
- Contaminated
Ianz18Avon wrote:Neil,
Yeah, like you'd ever need to know Ian
- Ben_Copeland
Just incase ...
8 gallons is 36litres
7 gallons is 31.8 (32)
Doh.... editted correctly
Ben
Ben_Copeland wrote:Just incase ...
8 litres is 36litres
7 litres is 31.8 (32)
did you mean gallons?
32L = 7.03 UK Gal
36 L = 7.9 UK Gal
In the Dax Rush I have the standard tank which I think is around the 30 ltrs. Doesn't go very far with the V6 3.2 and Holley carb pumping it in. Lucky to do 100 miles of average driving which is a real pain when your in the middle of nowhere...
I've brought a 20lt Jerry can to top up to save going down the station every time I go out.
Also I use Super. How much is that nowadays! Its madness!
Have fun Sunday doesn't look like I ll be able to make it as somethings come up. Quite literally, flying in the afternoon.
Clive.
Clive.
I have a 20 litre tank on standard locost and get about 110 miles on run to kings lynn so a mixture of motorwayand 30mph roads.
I think I'm in deep poo poo as mine only has a 20 Litre tank and a bit of a drinking problem.
.........Neil
.........Neil
