Week 3 in the MFTW series. You know how it goes. One post to declare the mission and a second to say if you achieved it.
So post away.
..............Neil
Mission for W/C 28th March 2010
Re: Mission for W/C 28th March 2010
Right.....
1/ Get a few stone chips tidied up
2/ check possible iffy wiring on the ECU Plug
3/ Stock up on bits n pieces for Detling - charcoal, drinks etc.
4/ Make up a car related/driving playlist for Detling.
5/ Persuade the missus that a new set of cams are essential.
It was going so well until you got to number 5
Mine is:
1. Run up Generator ready for next week........................................... Done
2. Buy Side Repeaters ASAP.............................................................To do
3. Get the Awning out of the back of the garage..................................Done
4. Try and get a day off work this week to sort bits with Indulgence........Challenging
........Neil
Mine is:
........Neil
It should be (has to be really...) a good week for me:
1) Finish wiring
2) First start
3) possibly throw some paint at it!
1) Finish wiring
2) First start
- Contaminated
1. Wash car
2. Tidy up stone chips on rear arches
3. Make a shift light
4. Install dual maps on the MJ and test the new one
5. Hoover out all the gravel inside the car!
Only one:-
GET THE FURY BACK ON THE ROAD!
Just needs a tax disc.
I'll also be starting the Ranger's engine swap. But that's not a target - as such.
- AshG
drive my car as much as i can
- Ben_Copeland
Continue building up the wall for the side of the garage.... Done with more to do
Look after my nutter son. .... Done and taught him a few more words
Ben
Right, and this maybe easy for me as I'm only working today and Tuesday this week, although Ive heard a rumour that Mrs B wants to go to the ideal home exhibition on Wednesday.....
1/ Buy a small buffer attachement for my drill and try to polish up my silencer properly
2/ Check my ignition wiring because I've blown two fuses in the last month for some unknown reason
3/ Check my nuts!, havent done this for a while and need to go over the car with a spanner
4/ Think of a good excuse for Wednesday
5/ Check my nuts - depending on how good the excuse for Wednesday was
Change oil and filter
Polish downpipes and exhaust
Pre-MOT check (MOT is next week)
Clean it - or persuade son it's an important part of his education that he does this for me
Assemble bits and pieces (HiViz vests, triangle etc.) for Le Blat
