Strange one
Moved tiger out of garage, so I could move cars and trailer around
Left tiger running on idle 5 - 10min at most
All of the sudden a massive bang,
a plume of steam around the nose of the tiger
Then dumped coolant in the road
Split the weld on the tank
Turns out the expansion tank is off a VW Jetta
surprising I thought it was all Ford
Guru Matt H knew straight away
Ordered one off eBay didn’t realise it had a extra hole, for a sensor.
so now gone for a level sensor, might come in handy,
when I get around to wire it up to a light
Run up the tiger, bled the system, went over 100degrees and the fan didn’t cut in.
So maybe fan temp switch faulty.
Tested the fan
(got a manual override for the fan on dash )
Shorted the temp switch and fan comes on as well
New fan temp switch it is then
Tiger went boom !!
Tiger went boom !!
Re: Tiger went boom !!
Well, that's pretty uncommon! If it was going to go, much better for it to happen mid winter and very close to home
Fitting a sensor makes a lot of sense and isn't too tricky.
Oh definitely, luckily I was at home,
- Jasonmpk
Well done, I had the same fan temp switch issues recently after rebuilding my engine, so a new switch has been fitted along with a controlling relay to keep the main current away from the stat switch directly and due to the over boiling I've fitted a dash override switch too. So hopefully they'll both be better for run outs this year.
Has the new bottle got a new cap?
If the pressure relief valve in the cap was jammed it'd do that. If it's still the old cap it might be worth checking.
Fury1630 wrote:Has the new bottle got a new cap?
No it didn’t, I thought it might of done
I was going to order a new one as well when I find the fan temp switch
Cheers Tony
Jasonmpk wrote:Well done, I had the same fan temp switch issues recently after rebuilding my engine, so a new switch has been fitted along with a controlling relay to keep the main current away from the stat switch directly and due to the over boiling I've fitted a dash override switch too. So hopefully they'll both be better for run outs this year.
Let’s hope so, I’m missing not going out on a nice Sunday drive
Got a couple other jobs to do as well, before she ready to hit the road
What temperature switch did you go for
Where did you get yours from
[*I’m missing not going out on a nice Sunday drive]
So is your car okay now Kev ? running okay now ?
- Jasonmpk
I went for a Burton one as my engine is a xflow, but I went for a 95 degree setting stat switch while the engine stat lets it pass once 90, (am waiting to get shot down) they also sell them for Zetecs and they know what you'll need.
Cheers Jason
My old one says 90degrees but no part numbers
But talking to matt he says zetecs run hot anyway
I’ll have a look on their website
