It's good to avoid having to buy any more
Hope all goes well.
The next engine woes
- Jasonmpk
Re: The next engine woes
A massive thank you to Matt who popped round this evening to sort the timing on my car, it appears that the car broke down after changing timing by about 90 degrees !!!!!
So it now runs very well again, I just need to sort a small water leak and paint a 'tell tale' line across the dizzy fixings just in case it moves again. The bike carbs also need a slight resetting across them to get a perfect purr from the engine for the first time i think
Once again,
THANKS MATT
Your a star
Once again,
THANKS MATT
Your a star
Well done Matt
Well done guys
Re the ignition, maybe a bit OT, but at every opportunity I’ll bang on about just how much of an improvement 3D mapped ignition is over clockwork. Back when we had a Xflow in the Westy, I had a spare Emerald ECU kicking about and decided to fit it to try and solve the perennial difficult-to-crank issue due to the 11:1 CR and 10 degrees static timing advance.
Good grief, what an improvement. It sorted the cranking/starting issue of course, as I set cranking timing to 5 degrees, but the unexpected and massive improvement in driveability throughout the range was a revelation. Given the engine had been properly set up when it got new 40s and had the carbs jetted and the dizzy re-curved I’d assumed up until that point that it couldn’t be improved on. The big hole up to about 3k rpm that I had always accepted was ‘a feature’ went away, better mpg, easy starting, more responsive everywhere.
A project to consider perhaps, fit 3D mapped ignition! You won’t regret it.
- Jasonmpk
ChrisS wrote:Re the ignition, maybe a bit OT, but at every opportunity I’ll bang on about just how much of an improvement 3D mapped ignition is over clockwork. Back when we had a Xflow in the Westy, I had a spare Emerald ECU kicking about and decided to fit it to try and solve the perennial difficult-to-crank issue due to the 11:1 CR and 10 degrees static timing advance.
Interesting thoughts Chris, I'll definitely consider the comments If/when the struggle returns. It ran very well this Sunday so I think I'll leave it alone at the moment as I follow the rule, ' If it ain't broke, don't fix it'
