I have just had the same problem and returned the battery (6 months old) back to supplier (Tayna) for checking and starter (WOSP) back for checking / service. Turned out it was the starter's solenoid contacts that had failed.
In my case, when the starter just clicked, all gauges lost power and I had to wait 15 minutes to try again. That was very strange and no ifdea why.
It could be the battery, have you tried an alternative?
Auto Electrician Needed.
- Richard
Re: Auto Electrician Needed.
Richard.
- martinq357
Might be worth replacing the main feed from the battery to the starter, could be a bad crimp and cheap to try.
Electrical problems in cars can be a nightmare. Had a weird one on my old Mk2 XR2, similar issue except occasionally when you put the indicators or lights on, the whole electrical system would die, completely. Eventually it would spring into life. After pulling what felt like the whole car to pieces, I traced it to the main ignition feed crimp on the battery terminal.
- Alex.
Today was a good day. Rich (locost220) and Jason(mpk) popped round to help with a bit of fault finding, thanks guys!
We could find nothing wrong with the car wiring, impedances were in the right ballpark. The original starter was still not co-operating, just doing the clicky thing. Even out of the car, it still wasn't right.
Put the new high torque starter in, the one that just clicked a few days ago, and it started first push. And every subsequent push. Some choice words were uttered.
Even after getting up to temp, every push resulted in a started engine.
Test drive next, to get some proper heat in the engine bay. Arriving back in the garage, time for the real test, she started on the button.
So that is a tentative problem solved, we'll just have to wait and see if it lasts.
Back up plan
- Jasonmpk
And don't forget to sort some heat shield for those poor solenoids
Jason
Jason
- Richard
Could well have been a poor connection that self-sorted itself. Starters take a lot of current with my hi torque WOSP taking over 30 amps according to WOSP. A poor connection may easily not allow that current thus the clicking.
Richard.
