Garage News
Re: Garage News
Crikey, that is a tight fit Kev
Re: Garage News
I think I may have it fixed.
The Q has been getting worse, not starting easily, stopping after 30sec, not holding constant revs. Having changed from a Ford ECU to an Omex & still having the same symptoms was messing with my head. Earlier this week I'd turned the Low Pressure fuel pump up the other way & convinced myself it sounded better, but then the engine wouldn't start at all.
Yesterday in sheer desperation, I was testing the circuit across the switching side of the ECU relay, the fuel pumps were off, I turned the key to ign & the test lights came on, I turned the key to start & it started & settled into a perfect 800rpm idle - without the fuel pumps on!
I went in & thought about this & today I ran a new ign live from the fuse box bus to the relays, I swapped the "aftermarket" ECU relay for a Ford one & I re-loaded the map Omex had sent.
Turned the key, & after a little coughing, it settled into a perfect idle. It needs mapping, but I've driven it up & down the drive & it's pulling well, it's got up to 86° & stayed there (no front bodywork), so at the moment it's all looking pretty good.
Re: Garage News
Well done Tony, a good brain teaser to start the day off with
hope you will be out again soon.
Re: Garage News
It's always something simple it's just finding the b'stard that's the hard part. Well done
Re: Garage News
Well done Tony, hope it continues behaving itself
Re: Garage News
I've started using the Quantum as the daily car to iron out any wrinkles, it made 131bhp on the rolling road (twice what the CVH left the factory with - probably three times what it actually had) it's doing over 40mpg & fingers crossed someone's coming to buy it next week
Re: Garage News
Sounds like a flyer no Tony, hope the sale goes through
Re: Garage News
All the best with the sale Tony
Re: Garage News
Hasn't called back
Might send a text, see if there's a reason, but this was expected - spend two weeks in the garage to get the Stylus usable for Wales, then still own the Quantum.
No matter, I'll put it on e-bay in the spring.
