can anyone help with supplying a radio code?
i changed the battery on my Quashqai and now the whole system needs a code which i havent got - what info would i need to supply?
radio code
- Phil N
Re: radio code
Re: radio code
"The car radio code is indicated on many nissan models on a small white sticker inside the glove box. The unlock code will be labeled "Anti-theft radio code". Enter this code using the preset radio buttons of your nissan qashqai radio. You will hear a beep and then the radio will resume normal functions."
As found on the internet. It may or not be true
Re: radio code
ahhh yeah but....... lots of forums telling me thats what others had done and none of them work, even after they paid £14.95 for them
and.....i know theres some clever people out there with the right software to get the right code!
but, very helpful so far
Re: radio code
Green Indy wrote:"The car radio code is indicated on many nissan models on a small white sticker inside the glove box. The unlock code will be labeled "Anti-theft radio code". Enter this code using the preset radio buttons of your nissan qashqai radio. You will hear a beep and then the radio will resume normal functions."
i cant beleive i went out and looked! no, not true
Re: radio code
Do you have AA or RAC homestart? I'm sure they change plenty of Quashqui batteries.
Re: radio code
DJ. wrote:Do you have AA or RAC homestart? I'm sure they change plenty of Quashqui batteries.
Good point but unfortunately not. Looks like this could only be available from Nissan from what I’ve found out so far
Re: radio code
Silly question tony have you pulled the stereo out. Sometimes people write the code on it or atached the card to it. Have this issue so many times at work and sometimes you get lucky.
If its not there anywere take a picture of all the seriel codes on the unit as nissan will need them to get the code and they will charge you to remove the stereo to get them
Re: radio code
The challenge will be getting the radio unit out, it’s all moulded into the dashboard!
What I have done is enter the wrong code 3 times and the unit tells me what the serial number is ....
