Today’s break down
Re: Today’s break down
Postby David T » Fri Sep 06, 2019 5:24 pm
Sorry to hear about this. On the blacktop that bit that's missing on the oil separator, ie part that sticks into block, is plastic I think.
Looks like best way forward is another engine and a coffee table project ;-)
Postby Kegco » Fri Sep 06, 2019 5:51 pm
Oil pick up we are not sure, what the thin strips that have been sucked up are from.
any ideas
Postby Kegco » Fri Sep 06, 2019 5:58 pm
David T wrote:Sorry to hear about this. On the blacktop that bit that's missing on the oil separator, ie part that sticks into block, is plastic I think.
Interesting but probably would of still damaged the engine, knowing my luck :lol:
Could be a new adventure St coffee tables
Kegco wrote:Oil pick up,
Postby b33fy » Sat Sep 07, 2019 7:43 am
What happened to the no 1 shell bearings? Looks like something spun on the con rod facing?
Postby Matth93 » Sat Sep 07, 2019 7:58 am
Yes they had spun but wether it was the cause of it or just from them being eaten away and then spinning I don’t know. I suspect they spun as they were being destroyed
Postby Kegco » Sat Sep 07, 2019 6:49 pm
Good afternoon, picked up the ST170 engine with Matt.
Took it back to matts and matt said we should try and start it before stripping it.
Cranked it over all moving ok.
Rigged a indicator light to oil pressure sensor and cranked it over using a bodged starter motor to get the oil pressure up. Looking good!
Out came Matt spare carbs, ECU, jump leads, string and sticky tape.
Postby Kegco » Sat Sep 07, 2019 7:04 pm
First run started on the button/ on the wire :lol:
https://youtu.be/KjekvJKla6s
Postby Kegco » Sat Sep 07, 2019 7:09 pm
Then got carried away and started to strip it down
Postby Kegco » Sat Sep 07, 2019 7:12 pm
Oil breather difference
