A little while ago I had trouble with one of my rear lights which when I took it apart I found it corroded inside. I’ve been wanting to change the rear lights anyway so bit the bullet and bought some new ones.
Yesterday I stripped the old ones off to do the swap. I found the new mounting almost lined up with the original holes in the arch so with opening the holes up slightly they bolted straight on. I’ve also done away with the fog and reverse lights on the back panel and put them on the arch too.
The indicators are flashing a bit fast now but I have a flasher unit on order for the led lights which should be here tomorrow
Rear lights
Re: Rear lights
Nice one Matt, same as mine.
Re: Rear lights
nice one Matt
