Postby locost220 » Mon Apr 22, 2019 5:52 pm
As previously mentioned I have been having issues with the driver's side arm rest area where I had bent the Ali panel round, I had tried to fill the area but whenever i put the side panel off and on there was far too flex and it had cracked so was time to remove what I could and try the Ali welding stuff I picked up previously at car show.
The demonstrator needs to give me some lessons.
Had to patch up some holes and put in new pieces to attach to and now seems far more stable . Another skim of filler and a bit of smoothing and looking far better.
I will be covering this area that is usually well used with a removable pad but good to know it is now sorted.
Skim of filler and a light sand
Filed down the excess
Ali 'welded'
New piece being fitted
Attempted repair made it worse initially
Areas kept on cracking so something had to be done.
Postby locost220 » Tue Apr 23, 2019 8:41 pm
Just a little bit of work in the garage this evening, been putting this one off for a while exspecting it to be a mare
The carbon effect light pods have long since seen better days and after realising the ones kindly donated by Tony H are 7'' compared to my 5 3/4 something had to be done.
After contacting a couple of kit car suppliers and eBay watching it seems pods alone that match up with my LED units are not to be had so armed with my new favourite tool, the flat block and 80 grit Velcro strip I attacked the carbon effect with gusto and then with 320 to smooth it out and then the rest of the bits for the same attention till I got to a reasonable standard about ready for some filler primer
Took about 90 mins so far easy to see where the time goes and still got the other one to start as well
Postby Nash » Tue Apr 23, 2019 10:29 pm
Rich, is the intention to have them hydrodipped?
Postby locost220 » Wed Apr 24, 2019 5:58 am
i had not really given it much though Neil, my default would have been satin black rattle can but looking how the black ring had already suffered chips having been on there 2/3 years and that was painted at home i could do with some thing more durable.
being that it is brass i cannot use my DIY powder coat
Postby Phil N » Wed Apr 24, 2019 7:27 am
Wouldn’t the film from hydrodripping it still suffer from stone chips? Not sure as I’ve never used it
Postby DJ. » Wed Apr 24, 2019 10:46 am
You may not like the look, but my stainless lights are fine after 8 years and nearly 40,000 miles. I saw a Caterham less than 2 years old with the black lights and there was a rust streak on one of them.
Postby Fury1630 » Wed Apr 24, 2019 8:09 pm
Lacquer the brass & call it steampunk :D
Postby locost220 » Fri Apr 26, 2019 4:56 pm
There goes the budget for the rest of the rebuild.
Least I got a free bag of sweets.
Postby Kegco » Sat Apr 27, 2019 8:35 am
locost220 wrote:There goes the budget for the rest of the rebuild.
Yeah I got a bag of sweets with mine, you would think the instructions would be more useful :D
ChrisL
Postby ChrisL » Sun Apr 28, 2019 6:49 am
Interesting choice, what swayed you to an ME22?
