have you got any wiring for the injection side to be able to get it running? ie/ from the ecu to whatever sensors?
yep got a system from Dick plus TB all laid in place and plugged in where possible, keep up at the back that was page 27.
Managed to try a few new toys during today 2 hr sparkless cleaning of the tank, (got to say when it got a good bite that expiry stuff sure does stick).
A mini belt sander and an air operated mini sander that takes the Velcro disc types, both purchased from the NEC chassis car auto jumble.
Both good bits of kit, the belt sander better for the paint removal, I hope to spend a few days attacking the fibreglass body panel repairs over Xmas the the mini sander should come into it own.
Sounds excellent Rich
Gulp, had a couple of comments/suggestions that i need to get a list together and work through it, well with my I.T. skills mean i can't work out how to attach an ExCell spreadsheet ( which does include what is needed to progress these so i do i not get stuck wanting on a sunday afternoon), But here are the headlines in capital and the sub sections
FUEL SYSTEM,
Tank Sump
HP Pump and mounting
Filter and mounting
repair fuel pick up
paint tank/ straps
OIL CATCH CAN
position and mount oil catch can
ECU SYSTEM
Electrical Plugs
ECU indication lights
BRAKE PIPES
Fit all to test then replace all
sort servo/ TB interference issues
accelerator cables
WIRING LOOM
Make sure car runs and all systems work
all fixings points
tape up loom
label terminations
make off terminals
WATER SYSTEM
check fan switch wiring
radiator hoses
paint fan and radiator
ROLLCAGE
Make conduit trial
try out windscreen
Make reinforcement points on chassis
Weld all together
paint rollcage
BODYWORK
repair rear arches
remove grill and indicators
repair nose cone
repair bonnet
repair scuttle
repair rear panel
make new side panels
make new vent panels
replace metal bulkhead within scuttle
Paint all body panels
Make new rear arch guards
make front arch extentions
CHASSIS WORK
filler arch supports
seam weld all joints
prep paint
paint chassis
SUSPENSION
Paint all sus parts
shock absorber overhaul
WHEELS
get wheels overhaul
HEADLIGHTS
replace bowls and grind the rings
Paint the fixings
ENGINE REFRESH
WING MIRROR
should all be done by New Year
Richard.
FUEL SYSTEM,
Tank Sump
Filter and mounting
repair fuel pick up
paint tank/ straps
OIL CATCH CAN
ECU SYSTEM
Electrical Plugs
BRAKE PIPES
accelerator cables
WIRING LOOM
all fixings points
tape up loom
label terminations
make off terminals
WATER SYSTEM
radiator hoses
ROLLCAGE
Make conduit trial
try out windscreen
Weld all together
paint rollcage
BODYWORK
repair rear arches
repair nose cone
repair bonnet
repair scuttle
repair rear panel
CHASSIS WORK
prep paint
paint chassis
SUSPENSION
Paint all sus parts
WHEELS
get wheels overhaul
HEADLIGHTS
Paint the fixings
ENGINE REFRESH
WING MIRROR
Richard.
That may look a long list but with your skills you will get through it.
K
K
Maybe ask Santa to borrow an Elf or two from his work force. I recon there will be a few idol hands with some spare hours come December 26th!
Well done though Rich. Your progress is evident even to those of us who have only attempted smaller jobs on our cars. So good luck with “the list” and moving forward to completion in 2019.
Is that all? So we’ll see you out and about in january then
Sounds like we need a good old fashioned SKCC Sunday run ending at your place for a few hours “all hands on deck” session?
Tony B wrote:Sounds like we need a good old fashioned SKCC Sunday run ending at your place for a few hours “all hands on deck” session?
Sounds like a good idea, but please no gelcoat work, or for that matter wiring, you have previous
