Update
Update
Postby Matth93 » Wed Aug 24, 2022 4:00 pm
I forgot to post after the July meeting sorry. I finished 4th in the first heat. In the second heat as I came out of the bend in 3rd place the throttle pedal went awol literally! It had come off its mounting and was under the other pedals (it’s fly by wire not a cable), I managed to limp the car off the track but couldn’t refit it till I got out of the car :cry: even worse luck with Darren (points leader) following me in as his car had boiled it’s brains out due to water pump failure.
I then got 4th in the final but all day the car didn’t feel like it quite had its normal powe. When I plugged it in back home it had a fault code for the brake and throttle being pressed at the same time which had reduced the power ( must remember to take a scanner to every meeting )
Return to “Matt and Kevs Outlaw Racing 2022 Dates”
