IVA Questions
Sabot
IVA Questions
Postby Sabot » Mon Mar 05, 2018 5:15 pm
Hi,
I am starting to think about getting my car ready for IVA and have a couple of questions that I am hoping one of you can answer for me.
My car is a classic Mini derivative which uses the subframes, engine, gearbox, suspension and various other parts from the Mini which are attached to a new fibreglass bodyshell. Would that fall under the 'basic' or 'normal' IVA test?
I have also been told by someone that this kit may struggle with the IVA because of the straight lines of the body. What are peoples thoughts?
Thanks in advance?
Chris
Status Sabot
bigstuff
Re: IVA Questions
Postby bigstuff » Mon Mar 05, 2018 6:40 pm
Re: IVA Questions
Postby greenwoo » Mon Mar 05, 2018 6:52 pm
sorry not a clue from me, but may be worth asking a manufacturer who is used to putting kits thru the test? i'd imagine that MEV might have some insight.....
Re: IVA Questions
Postby Fury1630 » Mon Mar 05, 2018 8:55 pm
Can't help with the "basic" or "normal" - but I suspect it'll be the normal.
The straight edges themselves aren't a problem, it the radius that's the thing. I THINK the figure is 2.5mm rad, so if that's right any GRP corner should be fine. Where there are actual edges (under the front bumper), there's a load of trim available, but it's only a problem if it can be touched by a "ball-on-a-stick" of a certain radius. The bolts under the bumper (holding the shell on?) & those on the suspension arms below will need plastic covers. The bonnet catches might fail (CBS do something similar that will pass.
All the details are in the IVA manual.
Re: IVA Questions
Postby David T » Tue Mar 06, 2018 7:30 am
I would suggest a good read of the IVA manual and maybe even replicate the tools to check compliance yourself (some pics here: https://www.gov.uk/government/publicati ... nstruction).
I would check your light positions too. You will need some side repeaters visible from the rear quarter.
Good luck with it - it's nice to see something a little different.
Sabot
Re: IVA Questions
Postby Sabot » Tue Mar 06, 2018 8:34 am
Thanks for all the replies.
Some useful info and it looks like I have lots of reading to do.
Feel free to post any other useful hints and tips you think of.
Chris
Status Sabot
Re: IVA Questions
Postby Phil N » Tue Mar 06, 2018 12:32 pm
Is it amphibious?
Sabot
Re: IVA Questions
Postby Sabot » Tue Mar 06, 2018 12:51 pm
Phil N wrote:Is it amphibious?
No, but if it doesn't get through the IVA, it may end up in a canal!! :lol: :lol:
Chris
Status Sabot
Re: IVA Questions
Postby steve m » Tue Mar 06, 2018 7:40 pm
Has it never been registered? or motd?
If it was my car ................
I would obtain a mini log book and drive it on that
As that is exactly what people did years ago with kit cars
Re: IVA Questions
Postby steve m » Tue Mar 06, 2018 7:44 pm
hahahah Phil, you quite obviously never owned or drove a 1960's mini ?
They would suffer with water ingress into the distributor in mild fog, let alone proper water coming in the front, that would shut the car down, the best remedy is a rubber glove over the dizzy with all the 5 leads through the fingers and tie wrapped tight
