internal protection for the IVA test
Re: internal protection for the IVA test
Postby Fury1630 » Thu May 11, 2017 11:24 am
teesquare100 wrote:i also need to get a choke cable fitted somewhere , i guess that might be a safety issue if it sticks out the dash anywhere
Have you used a Sierra steering column? If so there are mountings underneath for the bonnet release - I used the standard Sierra bonnet release handle & cable for the choke. It won't lock in place, but I found that pulling it on while cranking & for maybe 30 secs after it fires was enough.
Just a thought.
Postby locost220 » Thu May 11, 2017 3:32 pm
Isn't there still an exclusion zone within a defined diameter of the centre of the wheel that a choke knob could go.
Regard's Richard
Richard.D
Postby Richard.D » Thu May 11, 2017 5:15 pm
That's what I'm hoping for - I've just mounted mine to the right of the steering wheel.
Not sure how big the exclusion zone is but fingers crossed it'll be ok.
Blue Dax Rush 2ltr Pinto - Built and sold
Blue Dax 427 5.7ltr Chevy - Built and sold
Blue Dax Rush Cosworth turbo - rebuilt and sold
Black Dax Rush Cosworth turbo - finished off and sold
Black Dax Rush V8 - completed 2018 and on the road.
teesquare100
Postby teesquare100 » Tue May 16, 2017 9:07 am
Just a thought.
hiyah ... thanks for reply ...i will go and have a look that could be an easey fix ,, you are right though, mine is a pinto with dellortos .it dose not need much choke to get going .
regards bernie
teesquare100
Postby teesquare100 » Tue May 16, 2017 9:08 am
locost220 wrote:Isn't there still an exclusion zone within a defined diameter of the centre of the wheel that a choke knob could go.
Regard's Richard
i think you are right there ,,,100mm clearance ,, round the steering wheel ,, good place i think
cheers bernie
teesquare100
Postby teesquare100 » Tue May 16, 2017 9:10 am
Richard.D wrote:That's what I'm hoping for - I've just mounted mine to the right of the steering wheel.
i shall have a look at that ..i think your right
regards bernie.
