heated jackets and gloves
Postby leegav » Mon Nov 18, 2019 3:02 pm
i know this has been discussed before butnever felt the need for one.. however, im getting cold these days... any reccomendations on heated gloves and jackets apart from the market best like keiss etc. anyone used cheap ebay jobbies?
Re: heated jackets and gloves
Postby Tony B » Mon Nov 18, 2019 5:19 pm
https://www.sportsbikeshop.co.uk/motorc ... rod/219868
Gerbing products are very good, these are thee gloves I have, would recommend the jacket too as you only need a T-shirt underneath on even the snowy mornings
nelmo
Postby nelmo » Tue Nov 19, 2019 8:03 am
It may not be the same thing but I bought a cheap heated seat thing off eBay, plugged it into the cigarette lighter socket and it screwed the car up totally - idle all over the place, misfiring etc - undriveable.
Maybe drawing too much power, leaving not enough for the ECU? I don't know...
Like I said, heated clothing might be different but just my experience.
Postby leegav » Tue Nov 19, 2019 11:12 am
that wouldnt happen in a normal car so shouldnt in a kit surely...
Postby locost220 » Tue Nov 19, 2019 1:35 pm
nelmo wrote:It may not be the same thing but I bought a cheap heated seat thing off eBay, plugged it into the cigarette lighter socket and it screwed the car up totally - idle all over the place, misfiring etc - undriveable.
Did you let Tony B wire you car Neil ?
I have used the battery type gloves from Ebay Lee and although they work enough to keep the chill off the back of your hand not sure you will get enough life out of them for an early morning blatt .
I used heated gloves, quite thin and did not look like they would hold up well in rough treatment so I wear then inside the cheap ebay ones ( without the batteries ) and work really well.
if you feeling skint then could have a go making your own heated inner jacket like a few of us have ( did a thread on mine )
nelmo
Postby nelmo » Tue Nov 19, 2019 8:24 pm
leegav wrote:that wouldnt happen in a normal car so shouldnt in a kit surely...
Actually, that's a good idea - I should try it in my tintop...
Postby Tony B » Tue Nov 19, 2019 8:37 pm
Errr, cheek :lol: , although I suspect that Neils issue is either a faulty eBay seat or however his car is wired!
I’ll have you know my DIY heated 80s duran Duran jacket was an excellent piece of kit too, it’s still in my wardrobe as a backup coat, however I’m not sure you could easily diy fit a wire mesh into a pair of gloves.
Postby greenwoo » Wed Nov 20, 2019 8:48 pm
i reckon it could be done to an inner glove and then those slipped into a 'main' glove.
Have to say that i enjoyed making my old homemade jacket. If you guys hadn;t been kind enough to club together for my proper heated gear.....i'd have done the MNk2 version. Running an extra circuit to give a truly 'high' setting ie/ running 2 circuits at the same time = high, and 1 solo circuit would be normal/low.
Postby Matth93 » Thu Nov 21, 2019 9:12 pm
I use a pair of bike heated gloves that are powered by the car they work well and no batteries to go flat
https://rover.ebay.com/rover/0/0/0?mpre ... 4540086031
kenton
Postby kenton » Sun Nov 24, 2019 5:18 pm
I use the Gerbing motorcycle heated glove liner. They are thin so don't hinder using your fingers
